Hi! Tell me please is there the way to create statistical reports during period?
For example if I whant to create the report from 07.01.2022 - 05.03.2022? How can I set this condition in report profile?
You can make a new report profile and include created at with after “07.01.2022” and created at before 05 03 2022. and I believe that will get you what you are looking for.
This is good idea but there is no way to add the same field twice. The field is not active if you will try to add it again. So there is no way to add two or more the same field.
