Rendering images inline via text module (incident report generation)
Hello, I have a question about how to achieve something in Zammad that I thought should be quite straightforward to implement … but I could be wrong!
Information:
  • Used Zammad version: 6.0.0-1689777408.47b4983d.jammy
  • Browser + version: Mozilla Firefox for Ubuntu / 115.0.2 (64-bit)
  • I want to automatically generate an incident report at the end of a troubleshooting procedure implemented through Zammad (just before closing the ticket).
  • This incident report should include the results of the step-by-step troubleshooting process that the agent follows.
  • If possible, I would like to generate this incident report by using a text module, which would reference the results of each troubleshooting step, stored as objects.
  • However, I cannot find a way to embed or display images inline in the text module in any way. I thought I could store an image in an object, but it doesn’t seem to be possible.
  • The closest object type I could find to an image object type was Text / URL, but this does not result in an image being displayed inline in the ticket via the text module.
  • Can create a URL object thus: Objects > New Attribute > Format: Text Field, Type: Url
  • Instead want to create an image object like this: Objects > New Attribute > Format: Image
Request:
  • Does anyone have any ideas as to how to solve this problem?
Thank you!
David Wenk
If there is a way, I think it would be in workflows. I have not used them yet, so I’m not much help.
We display images in text modules by writing the text in a online html editor. Insert the image there (base64 encoded or via url to our cdn) and the copy paste the formated html (not the code) to the text module.
BR wucherpfennig
