I have a problem when installing the database of Zammad by the rake command, and I need some assistance, perhaps someone can point out how to fix this.
When I try to run ‘rake db:create’ I get the following error:
rake aborted!
SyntaxError: /opt/zammad/lib/tasks/zammad/db/reset.rake:17: syntax error, unexpected keyword_ensure, expecting keyword_end
ensure
/opt/zammad/lib/tasks/zammad/db/reset.rake:27: syntax error, unexpected keyword_end, expecting end-of-input
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:50:in `load’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.2.3/lib/active_support/dependencies.rb:285:in `block in load’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.2.3/lib/active_support/dependencies.rb:257:in `load_dependency’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.2.3/lib/active_support/dependencies.rb:285:in `load’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/railties-5.2.3/lib/rails/engine.rb:650:in `block in run_tasks_blocks’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/railties-5.2.3/lib/rails/engine.rb:650:in `each’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/railties-5.2.3/lib/rails/engine.rb:650:in `run_tasks_blocks’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/railties-5.2.3/lib/rails/application.rb:515:in `run_tasks_blocks’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/railties-5.2.3/lib/rails/engine.rb:459:in `load_tasks’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/railties-5.2.3/lib/rails/railtie.rb:190:in `public_send’
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/railties-5.2.3/lib/rails/railtie.rb:190:in `method_missing’
/opt/zammad/Rakefile:7:in `’
