- Used Zammad version: 4.1.0
- Operating system: Debian 11
- Browser + version: no browser, just ssh
- It should be the rails console open when I ssh as root
zammad run console
or
zammad run rails c
- I get the following error:
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require’: libreadline.so.7: cannot open shared object file: No such file or directory - /opt/zammad/vendor/ruby-2.6.8/lib/ruby/2.6.0/x86_64-linux/readline.so (LoadError)
Full response: hastebin
Further Infos:
Since I haven’t found any Debian 11 repos yet, I installed zammad from the 10 repos. Could this possibly be the origin of the problem? If so, what is the easiest way to solve this? Thank you for any help!
