I’m working on suppressing inactive users within the autocompletion. I realized that probably the search method within users_controller.rb is responsible for this. Within this method, I see something like this:
# build result list
tickets = Ticket.search(
query: query,
condition: params[:condition].to_h,
limit: per_page,
offset: offset,
current_user: current_user,
I don’t understand why this is done. Why bother querying the tickets when in the end just a list of users should be generated?
Note: I’m not a ruby developer, so maybe my question is stupid… Thanks for helping anyway + best regards, Uli
I also just stumbled over this; luckily Discourse prevented me from opening a new topic.
This looks like a copy-and-paste error to me - that code block seems to originate from ./tickets_controller.rb
and was introduced in cf1626494047f27d8fe094a7b954e04fef0f182b:
commit cf1626494047f27d8fe094a7b954e04fef0f182b
Author: Martin Edenhofer <me@edenhofer.de>
Date: Fri Apr 13 09:22:55 2018 +0200
Implemented issue #1951 - Allow pagination in search result with more then 100 results.
tickets
isn’t actually used afterwards in users_controller.rb
. @thorsteneckel should I file a bug?
Yes - you’re both right. That’s a copy paste error. I already stumbled across it while applying a (currently) deactivated rubocop cop but unfortunately hadn’t hat the time to finish things
I’d love to merge a MR removing this unnecessary block!
I’ll look into it. In general - should I file a bug report before filing a merge request, or a merge request only?
Thanks! A simple MR is sufficient - the changes are pretty clear and only refactoring/maintenance.
