- Used Zammad version: 5.2.3
- Operating system: AlmaLinux
- Browser + version: Edge 106.0.13
Please can you point me in the right direction for any documentation about modifying the self-hosted version? Specifically, I am looking to adjust the frontend CSS font styles and colors, so I am looking for some information on which files are safe to modify without causing issues during updates. From looking around the forums I’ve seen a few posts that are specific to certain user’s needs but have not yet found any general guidance on how modifications are handled during updates or whether I need to adjust the existing CSS or if there’s a way to keep my modifications in a separate file which is applied on top of the base code
