Process unprocessed mails
  • Used Zammad version:
    6.3.1
    docker compose
  • Operating system:
    deb 11
process unprocessed mails
docker exec -ti zammad-docker-compose-zammad-railsserver-1 rails r ‘Channel::EmailParser.process_unprocessable_mails’
results in : error stack - failed DB connection
thus (now with environment)
docker exec -ti zammad-docker-compose-zammad-railsserver-1 /docker-entrypoint.sh rails r ‘Channel::EmailParser.process_unprocessable_mails’
results in:
I, [2024-06-10T12:02:59.520130 #289] INFO – : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2024-06-10T12:02:59.534849#289-6060] INFO – : Using memcached as Rails cache store.
I, [2024-06-10T12:02:59.535033#289-6060] INFO – : Using the Redis back end for Zammad’s web socket session store.
Please specify a valid ruby command or the path of a script to run.
Run ‘rails runner -h’ for help.
undefined method `process_unprocessable_mails’ for Channel::EmailParser:Class
as above
Is this function still there?
Is there a new syntax?
Where do I find it in the documentation?
thanks a lot
Hello @tsprich,
The commands changed for zammad 6.3 and is documented under:
https://docs.zammad.org/en/latest/admin/console/other-useful-commands.html
Shot: Login as user zammad and move to /opt/zammad folder then run ‘zammad rake xxxxxxx’ from documentation.
Regards,
Benjamin
Hi Benjamin,
thank you very much, that helped a lot.
Torsten
