Problem with updating system
  • Used Zammad version: 4.1
After sudo apt-get update i have problem with Zammad repository as follows:
Err:9 https://dl.packager.io/srv/deb/zammad/zammad/stable/ubuntu 20.04 Release
Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 178.63.71.248 443]
Reading package lists… Done
E: The repository ‘https://dl.packager.io/srv/deb/zammad/zammad/stable/ubuntu 20.04 Release’ no longer has a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Update your root certificates - DST Root CA X3 has expired.
This is a local issue on your end.
Found the problem - my FortiGate UTM was not prepared correctly for the DST Root CA X3 expiration. Got a workaround and was able to upgrade. Thank you for support.
The topic can be closed.
