Hi comm,
Today i was trying to add new ticket state but when i found the thread with rails solution occured a problem with rails : “Your Ruby version is 2.4.5, but your Gemfile specified 2.4.4”.
I’ve found many thread about it but noone can help me because usually the ruby version is older than gem version.
Someone can help me?
Thanks, cheers
sorry the problem has changed [EDIT],
when i try to run “rails c” with shell, it gives me this error :
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/connection_adapters/connection_specification.rb:246:in resolve_symbol_connection': 'development' database is not configured. Available: ["production"] (ActiveRecord::AdapterNotSpecified) from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/connection_adapters/connection_specification.rb:227:in resolve_connection’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/connection_adapters/connection_specification.rb:141:in resolve' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/connection_handling.rb:55:in establish_connection’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-import-0.25.0/lib/activerecord-import/import.rb:218:in establish_connection_with_activerecord_import' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/railtie.rb:124:in block (2 levels) in class:Railtie’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/lazy_load_hooks.rb:69:in instance_eval' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/lazy_load_hooks.rb:69:in block in execute_hook’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/lazy_load_hooks.rb:60:in with_execution_control' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/lazy_load_hooks.rb:65:in execute_hook’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/lazy_load_hooks.rb:41:in block in on_load' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/lazy_load_hooks.rb:40:in each’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/lazy_load_hooks.rb:40:in on_load' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/railtie.rb:120:in block in class:Railtie’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/initializable.rb:30:in instance_exec' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/initializable.rb:30:in run’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/initializable.rb:59:in block in run_initializers' from /usr/share/rvm/rubies/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:228:in block in tsort_each’
from /usr/share/rvm/rubies/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:350:in block (2 levels) in each_strongly_connected_component' from /usr/share/rvm/rubies/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:431:in each_strongly_connected_component_from’
from /usr/share/rvm/rubies/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:349:in block in each_strongly_connected_component' from /usr/share/rvm/rubies/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:347:in each’
from /usr/share/rvm/rubies/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:347:in call' from /usr/share/rvm/rubies/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:347:in each_strongly_connected_component’
from /usr/share/rvm/rubies/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:226:in tsort_each' from /usr/share/rvm/rubies/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:205:in tsort_each’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/initializable.rb:58:in run_initializers' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/application.rb:353:in initialize!’
from /opt/zammad/config/environment.rb:5:in <top (required)>' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/dependencies.rb:292:in require’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/dependencies.rb:292:in block in require' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/dependencies.rb:258:in load_dependency’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/dependencies.rb:292:in require' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/application.rb:329:in require_environment!’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/command/actions.rb:16:in require_application_and_environment!' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/commands/console/console_command.rb:96:in perform’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/thor-0.20.3/lib/thor/command.rb:27:in run' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/thor-0.20.3/lib/thor/invocation.rb:126:in invoke_command’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/thor-0.20.3/lib/thor.rb:387:in dispatch' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/command/base.rb:63:in perform’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/command.rb:44:in invoke' from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/commands.rb:16:in <top (required)>’
from bin/rails:9:in require' from bin/rails:9:in ’
