- Used Zammad version: 6.3.1-1718860451.0f341764.bullseye
- Operating system: Debian 12
- Browser + version: Chrome, 126.0.6478.127
When sending emails, the styles defined in application_wrapper.html.erb are used.
We recently upgraded Version 5.3 to 6.3, respecting the upgrade path, so we did the step to 6.0 inbetween.
Recently, we noticed that our outgoing messages aren’t using the configured font/size settings anymore.
We’ve investigated and found that there might be a problem with the ###html# variable within applicaiton_wrapper.html.erb.
In short, we used a slightly modified .erb file, so we swapped for the original .erb file which we kept, just in case.
However, even with the original .erb file our configured font/size settings weren’t beieng used.
We tried both, setting font/size via the rails console Setting.set(‘html_email_css_font’,…) and, after that, writing our desired settings into the .erb file, removing the ###html_email_css_font### variable, neither worked.
We kept investigating, removing style-settings bracket by bracket, to find out where the file breaks.
However, it wasn’t until we removed ###html### (and overwrote it with dummy-test, making outgoing e-mails completely useless ofc.) that we saw our style-settings taking effect again.
From Outlook, we pulled the source files of the mails, containing the html formatting.
We found that, when ###html### is used, zammad places a tag right after the first meta tag, thus rendering the later defined style settings ineffective.
When we replaced ###html### with a string, suddenly the emails were beeing sent with correct settings, no extra tags anywhere in sight.
I’ve attached screenshots, our used .erb files and the html-source files from the test emails for comparison.
Hope this is an easy fix!
Modified .erb
body { font-family:Arial,Sans-Serif; font-size: 14.5px; } img { outline: none; text-decoration: none; -ms-interpolation-mode: bicubic; } a:link { color: black; background-color: transparent; text-decoration: underline; } a:visited { color: black; background-color: transparent; text-decoration: underline; } a:hover { color: black; background-color: transparent; text-decoration: underline; } a:active { color: black; background-color: transparent; text-decoration: underline; } a img { border: none; } table td { border-collapse: collapse; } table { border-collapse: collapse; mso-table-lspace: 0pt; mso-table-rspace: 0pt; border: none; table-layout: auto; display: block; width: 100%; overflow: auto; word-break: keep-all; } table, pre, blockquote { margin: 0 0 16px; } td, th { padding: 7px 12px; } th { font-weight: bold; text-align: center; } col { width: auto; } p { margin: 0; } code { border: none; background: hsl(0,0%,97%); white-space: pre-wrap; } blockquote { padding: 8px 12px; border-left: 5px solid #eee; } pre { padding: 12px 15px; font-size: 13px; line-height: 1.45; background: hsl(0,0%,97%); white-space: pre-wrap; border-radius: 3px; border: none; overflow: auto; } ###html###original .erb
body { ###html_email_css_font###; } img { outline: none; text-decoration: none; -ms-interpolation-mode: bicubic; } a img { border: none; } table td { border-collapse: collapse; } table { border-collapse: collapse; mso-table-lspace: 0pt; mso-table-rspace: 0pt; border: none; table-layout: auto; display: block; width: 100%; overflow: auto; word-break: keep-all; } table, pre, blockquote { margin: 0 0 16px; } td, th { padding: 7px 12px; } th { font-weight: bold; text-align: center; } col { width: auto; } p { margin: 0; } code { border: none; background: hsl(0,0%,97%); white-space: pre-wrap; } blockquote { padding: 8px 12px; border-left: 5px solid #eee; } pre { padding: 12px 15px; font-size: 13px; line-height: 1.45; background: hsl(0,0%,97%); white-space: pre-wrap; border-radius: 3px; border: none; overflow: auto; } ###html###HTML Source received while using ###html###
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<style type="text/css">
body {
font-family:Arial,Sans-Serif;font-size:11pt;
img {
outline: none;
a img {
border: none;
table td {
table {
border: none;
table-layout: auto;
display: block;
width: 100%;
overflow: auto;
table,
pre,
blockquote {
margin: 0 0 16px;
td, th {
padding: 7px 12px;
th {
font-weight: bold;
text-align: center;
col {
width: auto;
p {
margin: 0;
code {
border: none;
blockquote {
padding: 8px 12px;
pre {
padding: 12px 15px;
font-size: 13px;
line-height: 1.45;
border-radius: 3px;
border: none;
overflow: auto;
</style>
This E-Mail was sent using the original .erb File.
& 2nd Mail:
body {
font-family:Arial,Sans-Serif,"Comic Sans";
font-size: 14.5px;
img {
outline: none;
a:link {
color: black;
a:visited {
color: black;
a:hover {
color: black;
a:active {
color: black;
a img {
border: none;
table td {
table {
border: none;
table-layout: auto;
display: block;
width: 100%;
overflow: auto;
table,
pre,
blockquote {
margin: 0 0 16px;
td, th {
padding: 7px 12px;
th {
font-weight: bold;
text-align: center;
col {
width: auto;
p {
margin: 0;
code {
border: none;
blockquote {
padding: 8px 12px;
pre {
padding: 12px 15px;
font-size: 13px;
line-height: 1.45;
border-radius: 3px;
border: none;
overflow: auto;
</style>
This E-Mail was sent using our modified .erb File.
