I think the problem is that we have ticket fields named in Cyrillic, I’ve got more detailed log:
D, [2018-10-25T08:04:14.303508 #1074] DEBUG -- : Getting 'resource' value (ZendeskAPI::TicketField): #<ZendeskAPI::TicketField {"url"=>"https://sanatorium.zendesk.com/api/v2/ticket_fields/32089309.json", "id"=>32089309, "type"=>"tagger", "title"=>"Внутренний статус", "raw_title"=>"Внутренний статус", "description"=>"", "raw_description"=>"", "position"=>7, "active"=>true, "required"=>false, "collapsed_for_agents"=>false, "regexp_for_validation"=>nil, "title_in_portal"=>"Внутренний статус", "raw_title_in_portal"=>"Внутренний статус", "visible_in_portal"=>false, "editable_in_portal"=>false, "required_in_portal"=>false, "tag"=>nil, "created_at"=>2016-10-20 07:23:38 UTC, "updated_at"=>2018-05-22 08:11:22 UTC, "removable"=>true, "agent_description"=>"", "custom_field_options"=>[{"id"=>35325789, "name"=>"В работе", "raw_name"=>"В работе", "value"=>"в_работе", "default"=>false}, {"id"=>35325809, "name"=>"Зафиксировано", "raw_name"=>"Зафиксировано", "value"=>"зафиксировано", "default"=>false}, {"id"=>35325829, "name"=>"Передано в разработку", "raw_name"=>"Передано в разработку", "value"=>"передано_в_разработку", "default"=>false}, {"id"=>40401569, "name"=>"Приостановлен", "raw_name"=>"Приостановлен", "value"=>"приостановлен", "default"=>false}, {"id"=>360000015999, "name"=>"Выполнена", "raw_name"=>"Выполнена", "value"=>"выполнена", "default"=>false}]}>
D, [2018-10-25T08:04:14.304026 #1074] DEBUG -- : Getting 'model_class' value (Class): Ticket(id: integer, group_id: integer, priority_id: integer, state_id: integer, organization_id: integer, number: string, title: string, owner_id: integer, customer_id: integer, note: string, first_response_at: datetime, first_response_escalation_at: datetime, first_response_in_min: integer, first_response_diff_in_min: integer, close_at: datetime, close_escalation_at: datetime, close_in_min: integer, close_diff_in_min: integer, update_escalation_at: datetime, update_in_min: integer, update_diff_in_min: integer, last_contact_at: datetime, last_contact_agent_at: datetime, last_contact_customer_at: datetime, last_owner_update_at: datetime, create_article_type_id: integer, create_article_sender_id: integer, article_count: integer, escalation_at: datetime, pending_time: datetime, type: string, time_unit: decimal, preferences: text, updated_by_id: integer, created_by_id: integer, created_at: datetime, updated_at: datetime, phone_number: string)
D, [2018-10-25T08:04:14.304243 #1074] DEBUG -- : Getting 'sanitized_name' value (String): "_"
D, [2018-10-25T08:04:14.304543 #1074] DEBUG -- : Cache read: ObjectLookup::Ticket
D, [2018-10-25T08:04:14.307572 #1074] DEBUG -- : ObjectManager::Attribute Load (0.7ms) SELECT "object_manager_attributes".* FROM "object_manager_attributes" WHERE "object_manager_attributes"."object_lookup_id" = $1 AND "object_manager_attributes"."name" = $2 LIMIT $3 [["object_lookup_id", 2], ["name", "_"], ["LIMIT", 1]]
E, [2018-10-25T08:04:14.308962 #1074] ERROR -- : ImportJob 'Import::Zendesk' failed: Problem with ObjectManager Attribute '_': At least one letters is needed
E, [2018-10-25T08:04:14.309348 #1074] ERROR -- : Problem with ObjectManager Attribute '_': At least one letters is needed (RuntimeError)
After “sanitizing” field name contains only “_” character, so import fails
