when more than 2 Postmaster filters are applicable and valid, for example to move Tickets to a specific groups…how does that work.
Is filtering “stopped” on the first match, or does the last filter take precedence over the one(s) before?
BR, Christian
I’vbe just tested that for you.
It does not stop at the first match, it will handle both matches.
The order is defined by alphabetical order of the filter names.
Please note that if you touch the same attribute, naturally the last filter wins
Thanks a lot!
Then…taking care of alphabetical order - or numbering - is my way to do that
BR, Christian
system
Closed
4
