Hi, I’d like to know if it’s possible, to use a “and” “or” condition for trigger.
The Example here:
I want Ebay Messages that have a certain word in the subject assign to a user or group.
But sometimes the sender address from ebay is different so I want to filter by the subject words.
I can only filter by one word but if the message is like the same but have a different word in it, I can’t add this word after “Question”, for Example “Urgent Question”.
To do that I have to create a hole new rule.
To get it visuell, my old ticket system solved the problem by adding a “or” option and I could use more than one word:
If it’s not possible I’d like to make a feature request here.
dvnkln
June 23, 2021, 11:30am
2
Hey @Cassiopeia23 ,
this request has already been made a lot of times on here + an open issue already exists on github:
opened 03:19PM - 13 Aug 18 UTC
enhancement
prioritised by payment
trigger
Please post:
- Feature requests
- Development questions
- Technical questions
### Infos:
* Used Zammad version: 2.6.x
* Installation method (source, package, ..): any
* Operating system: any
* Database + version: any
* Elasticsearch version: any
* Browser + version: any
* Ticket-ID: #1031039, #1060690, #1067221, #1072409, #1079103, #1079241, #1079346, #1079468, #1082065, #1080184, #1083072, #1083556, #1083611, #1084691, #1087205
### Expected behavior:
* When ever using conditions (e.g. for Overviews or Triggers) it should be possible to use OR condition (e.g. using the same type of statement more than once )
### Actual behavior:
* Zammad only allows AND-Conditions
* It's not possible to use a Statement type more than once per query
This applies at least to the following Zammad-Sections and should be done at all possible places, because the user would not expect the dialoges to be inconsistend:
- Overviews
- Trigger
- Scheduler
- Postmaster filters
- SLAs
- Time Accounting
The following applies to any Zammad-Section mentioned above, I'll use overviews as example
* Create a new overview, giving it a meaningfull name
* As condition, choose "OWNER is specific user AGENT A"
* press + for a new condition part
* try to choose owner, to make the condition match to AGENT B, too
=> won't work - this should be possible.
This Issue is to cover all request too 100%, thus the other issues will be closed and linked below:
#885
#1004
You’re probably better off voting that one up.
cheers
Ok thank you very much, than I was to bad in using the search function right.
system
Closed
August 14, 2022, 2:44am
4
