Possible to switch Dard Mode on mobile devices?
  • Used Zammad version: 6.0
  • Operating system: Debian 10.10
  • Browser + version:
    Chrome, Edge, Firefox, private windows, to no avail
  • There is an option at the mobile end for users to select if they need Dark Mode or not, just like what has been available on the desktop view
  • Only avatar option available, by default it was the Dark mode and users can’t switch it back to the normal white background color
Open the Zammad portal from mobile end
Hi @eavenhuang. There is no “light mode” on Zammad’s mobile view.
Dear @fliebe92 , is it even possible to change it from the backend code or configuration file via command line?
Hi @fliebe92 like @fliebe92 already mentioned, there is currently no light mode implemented inside the mobile view. So also no hidden flag that could influence this.
In the future, we will maybe add also a light mode for the mobile view.
Thanks both @fliebe92 and @dominikklein a lot!
