Possibility to change order of triggers in admin interface via d&d (or maybe also on other screens)
Hi there,
I found out triggers are working in the order they appear on the list in the admin interface BUT you can’t change the order you can only rename the triggers. e.g. 1_Triggername, 2_Triggername and so on.
It would be helpfull if you could change the order via drag and drop.
In my example some tickets get a label before notification triggers are activated.
Cheers,
Sascha
