Seems like the packager.io domain wasn’t renewed. Is there another source for packages now?
Domain Information
Domain: packager.io
Registrar: Gandi SAS
Registered On: 2013-06-13
Expires On: 2024-06-13
Updated On: 2024-06-13
Status: clientHold
Name Servers:
oh wow. No there isn’t. That’s our packager.
A colleague had still a cached IP on his system. Please note that the following is a workaround and should not stay in production when the issue has been addressed by packager.io. IPs may change over time - use at your own risk.
Within /etc/hosts
you can add a new line:
178.63.71.248 dl.packager.io
That should temporarily help.
The domain seems to be back in service.
Might take some time for all DNS servers to get hold of the change.
Make sure to remove this workaround if you implemented it.
