As (not) told in the Overviews part of the Docs, Tags are not part of the Attributes.
As i use Zammad to group tickets geographically, tagging them by application, i need to be able to create overviews for my operator for them to manage applications in their geographical scope.
Could you make it possible to create overviews with the tag attribute please ? This would be greatly appreciated, you have to believe me !
Many thanks for your external point of view, which was more than helpful.
Sometimes you’ve got to think out of the box…
I’ve created a custom field that’s perfectly adapted to my initial need, tags were a workaround actually (but i didn’t know before you told me about the custom fields).
Many thanks, i’ve managed to get a good solution !
