- Used Zammad version: 6.1.0
- Operating system: Debian 10
- Browser + version: not relevant
- Zammad update runs without any errors.
Exception in thread "main" java.lang.RuntimeException: starting java failed with [1]
output:
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (mmap) failed to map 8413773824 bytes for committing reserved memory.
# An error report file with more information is saved as:
# /var/log/elasticsearch/hs_err_pid2395.log
error:
OpenJDK 64-Bit Server VM warning: INFO: os::commit_memory(0x00000005ca800000, 8413773824, 0) failed; error='Not enough space' (errno=12)
at org.elasticsearch.tools.launchers.JvmOption.flagsFinal(JvmOption.java:119)
at org.elasticsearch.tools.launchers.JvmOption.findFinalOptions(JvmOption.java:81)
at org.elasticsearch.tools.launchers.JvmErgonomics.choose(JvmErgonomics.java:38)
at org.elasticsearch.tools.launchers.JvmOptionsParser.jvmOptions(JvmOptionsParser.java:135)
at org.elasticsearch.tools.launchers.JvmOptionsParser.main(JvmOptionsParser.java:86)
-> removing [ingest-attachment]...
-> Installing ingest-attachment
-> Downloading ingest-attachment from elastic
[=================================================] 100%
@ WARNING: plugin requires additional permissions @
* java.lang.RuntimePermission accessClassInPackage.sun.java2d.cmm.kcms
* java.lang.RuntimePermission accessDeclaredMembers
* java.lang.RuntimePermission getClassLoader
* java.lang.reflect.ReflectPermission suppressAccessChecks
* java.security.SecurityPermission createAccessControlContext
See https://docs.oracle.com/javase/8/docs/technotes/guides/security/permissions.html
for descriptions of what these permissions allow and the associated risks.
-> Installed ingest-attachment
-> Please restart Elasticsearch to activate any plugins installed
Elasticsearch is running and seems to work, so maybe this is nothing to worry about—I still wanted to post it here, just in case anyone. Anything else I should check?
