- Used Zammad version: newest
- Used Zammad installation type: (source, package, docker-compose, …) package
- Operating system: ubuntu server 20
- Browser + version: chrome 92
- I go to http://localip-of-zamad-box:3000/ and see the web interface after install
- I get ERR_CONNECTION_REFUSED
- install zammad, confirm zamad-web is running, try to access web ui
root@zammad:/home/ian# systemctl status zammad-web
● zammad-web.service
Loaded: loaded (/etc/systemd/system/zammad-web.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-09-03 06:55:34 UTC; 20min ago
Main PID: 7917 (sleep)
Tasks: 1 (limit: 1631)
Memory: 164.0K
CGroup: /system.slice/zammad-web.service
└─7917 /bin/sleep infinity
This is before any proxy/SSL setup on the zamad box - I do have a reverse proxy I use for a lot of other things pointing to Zamad but as it doesn’t work with the direct IP I don’t think it’s a proxy issue. Why can I not see the web ui after install?
