- Used Zammad version: 3.6
- Operating system: UBUNTU 18
- Browser + version: chrome
- Login to zammad without CSRF token verification failed!
- CSRF token verification failed! Can’t reconfigure reverse proxy to correct IP address
- Follow tutorial to install in ubuntu configure reverse proxy in another machine
Hello community!
I am using a NGINX reverse proxy in a separate machine to serve my zammad app. (packet ubuntu 18). I want to know how can I change ruby’s listening IP address, 127.0.0.1 by default. I want to change to the server Private IP address, if not my reverse proxy can’t access localhost because it is not in the same machine. Here are my confs:
Nginx reverse proxy in another machine:
upstream zammad-railsserver {
server 192.168.xx.xx:3000; <-- Zammad Server Private IP
upstream zammad-websocket {
server 192.168.xx.xx:6042; <-- Zammad Server Private IP
server {
listen 443;
server_name zammad.fqdn;
server_tokens off;
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
location / {
# Change this line in an SSO setup
proxy_read_timeout 300;
gzip on;
gzip_proxied any;
# http redirect to https
server {
listen 80;
server_name zammad.it-work.fr;
if ($host = zammad.it-work.fr) {
return 404;
