Nginx for reverse
  • Used Zammad version: 6.3.1
  • Operating system: ubuntu2204
  • Browser + version:
change the url and we can access for the website
change the /opt/zammad/nginx/zammad.conf
I dont know how to change the nginx file for zammad , the default file it confused me .
I using my own nginx.conf that like
server {
    listen 80;
    server_name support.mydomain.com;
    # 将HTTP请求重定向到HTTPS
    location / {
server {
    listen 443 ssl;
    ssl_certificate /etc/nginx/ssl/fullchain5.pem;  # 修改为你的SSL证书路径
    ssl_certificate_key /etc/nginx/ssl/privkey5.pem;  # 修改为你的SSL证书私钥路径
    # 强制使用较强的SSL协议和加密套件
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_ciphers HIGH:!aNULL:!MD5;
    location / {
        proxy_pass http://192.168.8.201:8080;  # 修改为你的后端服务地址
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
    # 如果需要添加其他配置,请在此处添加
when i docker-compose up ; and change http_type to https;we met the error CRSF auth failed when new user reg for our site ;
I try to change the container 's file for zammad.conf and zammad_ssl.conf by chaning the proxy_set_header X-Forwarded-Proto $scheme to proxy_set_header X-Forwarded-Proto https ; It does’t work ~
I change the docker-compose.yml to original version ,and enable the variale for NGINX_SERVER_SCHEME=https
Now it is worked for that ; I can receive the email that address is https not http;
