We would like in trigger to use the conditions (group) multiple times. We need this, as we can’t get a notification when a ticket moves from a group to a new group. Agent should get informed about this.
It’s only once available
Create a trigger and try to use any condition more than once
That’s not possible. For how central a feature triggers and such are, the implementation is really sub-par in Zammad, unfortunately… guess they backed themselves into a technical corner early on and it’s hard to get back out again.
For workarounds, depending on the specific need, that can sometimes be done by extending the object in question or by a script that uses the API / parses the DB / uses the console and reacts to things that triggers to - we’ve implemented some fairly complex things that way. You could also try consuming from websocket and reacting to that, but I haven’t done that yet and don’t know how much information gets sent.
In my opinion you should never ever force your agents to receive notification they don’t want.
If you do that, you risk them setting up filter rules to ignore those mails and thus also loose track of things that are really important to them.
