Multiple Tags operations in a Trigger or Makro
The automation possibilities in zammad with triggers, schedulers and macros would be great, if it weren’t for the limitation that only one operation on tags is possible at a time. Could this restriction not be dropped?
I want to
  1. Remove a tag
  2. Add another tag
  3. Add another tag
Regards
Patrick
Thank you for bringing this up.
For further explanation, here is a screenshot of the affected place
