Used Zammad version: Zammad version 6.4.0-1732617118.28f54743.jammy
Used Zammad installation type: (source, package, docker-compose, …) Package
Operating system: 22.04
Browser + version: Chrome Current
To work on mobile client as this snip is in the nginx config:
# action cable
location /cable {
proxy_http_version 1.1;
proxy_read_timeout 86400;
location / {
connection to server lost on mobile browser
I am using a cloudflare tunnel to present zammad to the web.
Maybe a config issue?
browse to public url on phone
I cannot login when browsing via ip as m365 sso doesnt work
Zammad expects that the FQDN and HTTP type are consistent from all clients you use. You cannot have several ones. So my guess is that you have an internal FQDN configured in Zammad which (of course) miss matches from what you’re using via Cloudfare. This would explain why the callback URL of Microsoft 365 are invalid and why your websocket doesn’t work.
Also see:
system
Closed
March 19, 2026, 11:28am
3
