bundle install --without test development postgres without any errors
zammad@zammad:~$ bundle install --without test development postgres
Fetching gem metadata from https://rubygems.org/.........
Fetching https://github.com/zammad-deps/mail
NOTE: Gem::Specification#has_rdoc= is deprecated with no replacement. It will be removed on or after 2018-12-01.
Gem::Specification#has_rdoc= called from /usr/local/rvm/gems/ruby-2.6.6/bundler/gems/mail-9265cf75bbe3/mail.gemspec:13.
Your bundle is locked to mimemagic (0.3.5), but that version could not be found in any of the sources listed in your Gemfile. If you haven't changed
sources, that means the author of mimemagic (0.3.5) has removed it. You'll need to update your bundle to a version other than mimemagic (0.3.5) that hasn't
been removed in order to install.
i reinstalled rvm as in the source install docs ontop of the old ways from previos docs version.
