I would like to merge existing users with LDAP users but some existing users are also in LDAP so I would like to transfer existing tickets to the correspondent new LDAP users.
What is the suggested way to do it? Can I manually replace id from users table?
For a more detailed explanation, let’s say that I have an existing user with id 20 (in users table) and a new one with id 35, coming from LDAP integration.
So I would like to move tickets of user 20 to user 35 and then remove user 20. Note that the new user (35) doesn’t have any activity at the time of merging/changing ID
I migrated succesfully all users. Here’s a SQL snippet code to change user ID 73 to 68 and user ID 79 to 81.
Just update the list in CASE statement and WHERE clause with your user list Use at your own risk!
karma_users table should be changed manually (i.e. remove rows with new user IDs before running the script)
UPDATE public.histories
SET created_by_id = CASE created_by_id
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHERE created_by_id IN (73, 79);
UPDATE public.ticket_articles
SET updated_by_id = CASE updated_by_id
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHERE updated_by_id IN (73, 79);
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.karma_activity_logs
SET user_id = CASE user_id
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHERE user_id IN (73, 79);
SET origin_by_id = CASE origin_by_id
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHERE origin_by_id IN (73, 79);
UPDATE public.roles_users
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.cti_caller_ids
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.taskbars
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.online_notifications
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.stores
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.activity_streams
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.stats_stores
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.karma_users
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.tickets
SET owner_id = CASE owner_id
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHERE owner_id IN (73, 79);
SET customer_id = CASE customer_id
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHERE customer_id IN (73, 79);
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHEN 73 THEN 68
WHEN 79 THEN 81
END
WHEN 73 THEN 68
WHEN 79 THEN 81
END
UPDATE public.recent_views
WHEN 73 THEN 68
WHEN 79 THEN 81
END
Dear future anon finding this thread via a wild internet safari / search:
Please note that above mentioned methods are dangerous and not supported.
Running above commands may lead to a broken system - don’t do it if you’re super sure what you’re doing.
A wild guess:
Login name and/or email address of your local user and your ldap users did not match.
This is the reason why Zammad couldn’t recognize the users correctly.
Your method is a very radical version which may break users and their relations.
