After upgrade to the latest version using the yum repository, some API URLs stopped working with 404
here is some detected from production.log
Started GET "/api/v1/tags/add?object=Ticket&o_id=116356&item=abusive+ad&_=1606161457329"
Processing by ErrorsController#routing as JSON
Parameters: {"object"=>"Ticket", "o_id"=>"116356", "item"=>"abusive ad", "_"=>"1606161457329", "a"=>"api/v1/tags/add"}
No route matches [GET] /api/v1/tags/add (ActionController::RoutingError)
Started DELETE "/api/v1/ticket_attachment_upload"
Parameters: {"form_id"=>"163030266", "a"=>"api/v1/ticket_attachment_upload"}
No route matches [DELETE] /api/v1/ticket_attachment_upload (ActionController::RoutingError)
Started GET "/api/v1/ticket_related/116356?_=1606161457335"
Processing by TicketsController#ticket_related as JSON
Parameters: {"_"=>"1606161457335", "ticket_id"=>"116356"}
Completed 200 OK in 178ms (Views: 28.9ms | ActiveRecord: 32.4ms)
Started GET "/api/v1/ticket_merge/116356/97116278?_=1606161457336"
Parameters: {"_"=>"1606161457336", "a"=>"api/v1/ticket_merge/116356/97116278"}
No route matches [GET] /api/v1/ticket_merge/116356/97116278 (ActionController::RoutingError)
while zammad run rake routes result for those three methods:
PUT /api/v1/ticket_merge/:slave_ticket_id/:master_ticket_number(.:format)
POST /api/v1/tags/add(.:format)
Please note browser cache is deleted and also tested on other browsers
