LDAP Sync hangs, how to cancel
Hi everyone. I need help :slight_smile:
I’ve setup LDAP Sync and it works in general. But since 03/13/2018 the import hangs. If I navigate to the settings i see the following
ldap
If i scroll down to the log section, i see also that the import works. The last Log entry was written 26 minutes ago.
But now I have to change some settings. But if I could only change settings if the sync is finish.
How can I cancle this process, that I can make some changes?
Try this
sudo -u zammad zammad run rails c
ImportJob.last
ImportJob.last.destroy
job = ImportJob.create(name: ‘Import::Ldap’, payload: Setting.get(‘ldap_config’))
job.delay.start
exit
should destroy the “running” Import Job and trigger a delayed new Import Job
Thank you it works. It would be great, if its possible to create a button for aborting this job :slight_smile:
maybe an zammad developer is reading this, and mark this as a feature request :wink:
