As i went through a few iterations to get the ldap filter syntax right…
Currently it will drop you back to the LDAP integration screen and you have to start again with the configuraton or change the existing one if you have an error in the LDAP filter. It will definitely save a few clicks if you had the possibility to go back to the filter settings screen inside the configuration wizard when something goes wrong.
And while we’re at it: It would also be nice to be able to edit just the LDAP filter right from the LDAP integration screen instead of going through the wizard every time…
