I’ve taken a look. It looks like your Zammad can’t find any users matching the configured filters you provided. Also, as you told Zammad to skip not mapped users, it will ignore all users it might have found. Ensure that your group mapping is good to go and also that your login attributes are working and fetchable.
Fire up a ldap browser (or so) and check if the user_filter above works for you. If so, also check the group filter. If that’s all right, check if you can find any users with the needed groups and the above filters.
To me it looks like Zammad is not able to map any role to the user which is why it’s skipping it.
