vim /opt/zammad/log/production.log
I, [2019-08-12T15:20:38.957598 #4093-47309402711020] INFO -- : Parameters: {"full"=>"true", "_"=>"1565603421722"}
I, [2019-08-12T15:20:39.002962 #4093-47309404792720] INFO -- : Completed 200 OK in 53ms (Views: 0.8ms | ActiveRecord: 15.2ms)
I, [2019-08-12T15:20:39.025619 #4093-47309402711020] INFO -- : Completed 200 OK in 67ms (Views: 0.8ms | ActiveRecord: 15.3ms)
I, [2019-08-12T15:20:39.094448 #4093-47309404791980] INFO -- : Started GET "/api/v1/ticket_stats?user_id=9&organization_id=&_=1565603421723" for 127.0.0.1 at 2019-08-12 15:20:39 +0530
I, [2019-08-12T15:20:39.138230 #4093-47309404791980] INFO -- : Processing by TicketsController#stats as JSON
I, [2019-08-12T15:20:39.138522 #4093-47309404791980] INFO -- : Parameters: {"user_id"=>"9", "organization_id"=>"", "_"=>"1565603421723"}
I, [2019-08-12T15:20:39.381710 #4093-47309404791980] INFO -- : Completed 200 OK in 243ms (Views: 24.0ms | ActiveRecord: 66.2ms)
I, [2019-08-12T15:20:39.531810 #4093-47309404791980] INFO -- : Started GET "/api/v1/ticket_stats?user_id=7&organization_id=&_=1565603421724" for 127.0.0.1 at 2019-08-12 15:20:39 +0530
I, [2019-08-12T15:20:39.554999 #4093-47309404791980] INFO -- : Processing by TicketsController#stats as JSON
I, [2019-08-12T15:20:39.555240 #4093-47309404791980] INFO -- : Parameters: {"user_id"=>"7", "organization_id"=>"", "_"=>"1565603421724"}
I, [2019-08-12T15:20:39.699845 #4093-47309340446920] INFO -- : Started GET "/api/v1/text_modules/?full=true&_=1565603421725" for 127.0.0.1 at 2019-08-12 15:20:39 +0530
I, [2019-08-12T15:20:39.732463 #4093-47309340446920] INFO -- : Processing by TextModulesController#index as JSON
I, [2019-08-12T15:20:39.732766 #4093-47309340446920] INFO -- : Parameters: {"full"=>"true", "_"=>"1565603421725"}
I, [2019-08-12T15:20:39.798465 #4093-47309340446920] INFO -- : Completed 200 OK in 65ms (Views: 0.7ms | ActiveRecord: 18.2ms)
I, [2019-08-12T15:20:39.926130 #4093-47309404791980] INFO -- : Completed 200 OK in 371ms (Views: 35.9ms | ActiveRecord: 93.5ms)
I, [2019-08-12T15:20:39.945708 #4093-47309404791980] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=9&_=1565603421726" for 127.0.0.1 at 2019-08-12 15:20:39 +0530
I, [2019-08-12T15:20:39.971679 #4093-47309404791980] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-12T15:20:39.971988 #4093-47309404791980] INFO -- : Parameters: {"customer_id"=>"9", "_"=>"1565603421726"}
I, [2019-08-12T15:20:39.984804 #4093-47309340446920] INFO -- : Started GET "/api/v1/tickets/25?all=true&_=1565603421727" for 127.0.0.1 at 2019-08-12 15:20:39 +0530
I, [2019-08-12T15:20:40.036607 #4093-47309340446920] INFO -- : Processing by TicketsController#show as JSON
I, [2019-08-12T15:20:40.036821 #4093-47309340446920] INFO -- : Parameters: {"all"=>"true", "_"=>"1565603421727", "id"=>"25"}
I, [2019-08-12T15:20:40.094873 #4093-47309404791980] INFO -- : Completed 200 OK in 123ms (Views: 13.3ms | ActiveRecord: 48.3ms)
I, [2019-08-12T15:20:40.317042 #4093-47309404791980] INFO -- : Started GET "/api/v1/text_modules/?full=true&_=1565603421728" for 127.0.0.1 at 2019-08-12 15:20:40 +0530
I, [2019-08-12T15:20:40.377738 #4093-47309376087040] INFO -- : Started GET "/api/v1/templates/?full=true&_=1565603421729" for 127.0.0.1 at 2019-08-12 15:20:40 +0530
I, [2019-08-12T15:20:40.387411 #4093-47309340446920] INFO -- : Completed 200 OK in 350ms (Views: 34.8ms | ActiveRecord: 97.5ms)
I, [2019-08-12T15:20:40.397914 #4093-47309404791980] INFO -- : Processing by TextModulesController#index as JSON
I, [2019-08-12T15:20:40.401339 #4093-47309404791980] INFO -- : Parameters: {"full"=>"true", "_"=>"1565603421728"}
I, [2019-08-12T15:20:40.412805 #4093-47309376087040] INFO -- : Processing by TemplatesController#index as JSON
I, [2019-08-12T15:20:40.413022 #4093-47309376087040] INFO -- : Parameters: {"full"=>"true", "_"=>"1565603421729"}
I, [2019-08-12T15:20:40.454314 #4093-47309404791980] INFO -- : Completed 200 OK in 53ms (Views: 0.7ms | ActiveRecord: 12.1ms)
I, [2019-08-12T15:20:40.463047 #4093-47309376087040] INFO -- : Completed 200 OK in 50ms (Views: 0.6ms | ActiveRecord: 16.9ms)
I, [2019-08-12T15:20:41.929818 #4093-47309404792720] INFO -- : Started PUT "/api/v1/taskbar/46" for 127.0.0.1 at 2019-08-12 15:20:41 +0530
I, [2019-08-12T15:20:41.949273 #4093-47309404792720] INFO -- : Processing by TaskbarController#update as JSON
I, [2019-08-12T15:20:41.949661 #4093-47309404792720] INFO -- : Parameters: {"key"=>"Ticket-26", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"433407756"}}, "params"=>{"ticket_id"=>"26", "init"=>true}, "prio"=>10, "notify"=>false, "active"=>false, "attachments"=>[], "updated_at"=>"2019-08-10T10:35:38.249Z", "id"=>"46"}
I, [2019-08-12T15:20:42.155597 #4093-47309404792720] INFO -- : Completed 200 OK in 206ms (Views: 1.9ms | ActiveRecord: 13.4ms)
I, [2019-08-12T15:20:42.283591 #4093-47309404792720] INFO -- : Started PUT "/api/v1/taskbar/57" for 127.0.0.1 at 2019-08-12 15:20:42 +0530
I, [2019-08-12T15:20:42.299624 #4093-47309404792720] INFO -- : Processing by TaskbarController#update as JSON
I, [2019-08-12T15:20:42.299918 #4093-47309404792720] INFO -- : Parameters: {"key"=>"Ticket-31", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"162245089"}}, "params"=>{"ticket_id"=>"31", "article_id"=>"36", "init"=>true}, "prio"=>16, "notify"=>false, "active"=>false, "attachments"=>[], "updated_at"=>"2019-08-09T09:57:35.937Z", "id"=>"57"}
I, [2019-08-12T15:20:42.423082 #4093-47309404792720] INFO -- : Completed 200 OK in 123ms (Views: 1.7ms | ActiveRecord: 10.2ms)
I, [2019-08-12T15:20:42.545657 #4093-47309404792720] INFO -- : Started PUT "/api/v1/taskbar/67" for 127.0.0.1 at 2019-08-12 15:20:42 +0530
I, [2019-08-12T15:20:42.563529 #4093-47309404792720] INFO -- : Processing by TaskbarController#update as JSON
I, [2019-08-12T15:20:42.563881 #4093-47309404792720] INFO -- : Parameters: {"key"=>"Ticket-2", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"433295754"}}, "params"=>{"ticket_id"=>"2", "init"=>true}, "prio"=>26, "notify"=>false, "active"=>false, "attachments"=>[], "updated_at"=>"2019-08-10T10:34:07.590Z", "id"=>"67"}
I, [2019-08-12T15:20:42.689227 #4093-47309404792720] INFO -- : Completed 200 OK in 125ms (Views: 1.8ms | ActiveRecord: 12.1ms)
I, [2019-08-12T15:20:42.727378 #4093-47309404792720] INFO -- : Started PUT "/api/v1/taskbar/71" for 127.0.0.1 at 2019-08-12 15:20:42 +0530
I, [2019-08-12T15:20:42.748653 #4093-47309404792720] INFO -- : Processing by TaskbarController#update as JSON
I, [2019-08-12T15:20:42.749100 #4093-47309404792720] INFO -- : Parameters: {"key"=>"Search", "client_id"=>"123", "callback"=>"Search", "state"=>{"query"=>"ticket creation", "model"=>"KnowledgeBaseAnswerTranslation"}, "params"=>{"query"=>"cti ", "init"=>true}, "prio"=>30, "notify"=>false, "active"=>false, "attachments"=>[], "updated_at"=>"2019-08-07T10:08:20.241Z", "id"=>"71"}
I, [2019-08-12T15:20:42.842346 #4093-47309404792720] INFO -- : Completed 200 OK in 93ms (Views: 1.7ms | ActiveRecord: 8.8ms)
I, [2019-08-12T15:20:42.928665 #4093-47309404792720] INFO -- : Started PUT "/api/v1/taskbar/72" for 127.0.0.1 at 2019-08-12 15:20:42 +0530
I, [2019-08-12T15:20:42.946502 #4093-47309404792720] INFO -- : Processing by TaskbarController#update as JSON
I, [2019-08-12T15:20:42.946847 #4093-47309404792720] INFO -- : Parameters: {"key"=>"Ticket-30", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"262764247"}}, "params"=>{"ticket_id"=>"30", "init"=>true}, "prio"=>31, "notify"=>false, "active"=>false, "attachments"=>[], "updated_at"=>"2019-08-09T08:22:02.460Z", "id"=>"72"}
I, [2019-08-12T15:20:43.094198 #4093-47309404792720] INFO -- : Completed 200 OK in 147ms (Views: 1.9ms | ActiveRecord: 13.2ms)
I, [2019-08-12T15:20:43.148998 #4093-47309404792720] INFO -- : Started PUT "/api/v1/taskbar/73" for 127.0.0.1 at 2019-08-12 15:20:43 +0530
I, [2019-08-12T15:20:43.167855 #4093-47309404792720] INFO -- : Processing by TaskbarController#update as JSON
I, [2019-08-12T15:20:43.168198 #4093-47309404792720] INFO -- : Parameters: {"key"=>"Ticket-29", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"264307027"}}, "params"=>{"ticket_id"=>"29", "init"=>true}, "prio"=>32, "notify"=>false, "active"=>false, "attachments"=>[], "updated_at"=>"2019-08-10T10:32:47.784Z", "id"=>"73"}
I, [2019-08-12T15:20:43.257342 #4093-47309404792720] INFO -- : Completed 200 OK in 89ms (Views: 1.5ms | ActiveRecord: 11.7ms)
I, [2019-08-12T15:20:43.392967 #4093-47309404792720] INFO -- : Started PUT "/api/v1/taskbar/77" for 127.0.0.1 at 2019-08-12 15:20:43 +0530
I, [2019-08-12T15:20:43.408294 #4093-47309404792720] INFO -- : Processing by TaskbarController#update as JSON
I, [2019-08-12T15:20:43.408566 #4093-47309404792720] INFO -- : Parameters: {"key"=>"Ticket-25", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"268316730"}}, "params"=>{"ticket_id"=>"25", "init"=>true}, "prio"=>36, "notify"=>false, "active"=>false, "attachments"=>[], "updated_at"=>"2019-08-08T13:19:02.840Z", "id"=>"77"}
I, [2019-08-12T15:20:43.502429 #4093-47309404792720] INFO -- : Completed 200 OK in 94ms (Views: 2.7ms | ActiveRecord: 10.5ms)
Email configuration is like this: (Admin -> channels -> E-mail)
