Inbound Mailsettings for pop3 and Exchange 2016
#1
We use an Exchange 2016 server and would like to pick up the mails via pop3
Blockquote SSL_connect returned=1 errno=0 state=SSLv3/TLS write client hello: wrong version number
Unfortunately, this error appears, what can I say?
#2
https://community.zammad.org/t/asking-for-help-on-community/2262/2
#3
Is there a form I can fill out?
#4
Yeah well you deleted it from the creation post.
### Infos:
<!-- **Important:**
**If you are a Zammad Support or hosted customer and experience a technical issue, please refer to: support@zammad.com using your zammad-hostname / or company contract.** -->
* Used Zammad version:
* Used Zammad installation source: (source, package, ...)
* Operating system:
* Browser + version:
### Expected behavior:
### Actual behavior:
#5
Used Zammad version: 2.9.0-1556788014.16325a31
Used Zammad installation source: https://dl.packager.io/srv/deb/zammad/zammad/stable/ubuntu 18.04/main amd64 zammad amd64 2.9.0-1556788014.16325a31.bionic
Operating system: Ubuntu 18.04.2 LTS
Browser + version: Firefox 60.6.1esr (64-Bit)
Conntection to Exchange 2016 over POP3 port 110 with SSL/STARTTLS
during configuration the error appears:
  • add email connection
  • select pop3, adress of the mailserver, user passsword,
  • switch ssl to yes
  • port 110
#6
Hey @tmueller,
i don’t know much about Exchange but “real” SSL POP3 should probably be on port 995.
Depends if you use SSL/STARTTLS.
cheers
#7
ok i am working on that
but if i use pop3 without encryption this error appears:
#8
Is Port 110 your unencrypted Port or the SSL port?
Sorry, but helping you is impossible with that information set.
#9
110 is Exchange 2016 POP with STARTTLS
so it should be work with port 110 an ssl/starttls set to yes
but if set it to that port using pop3
Blockquote
