Idoit integration not working
  • Used Zammad version: 3.6
  • Used Zammad installation source: (source, package, …) package
  • Operating system: Ubuntu 20.04.1 LTS (GNU/Linux 5.4.0-58-generic x86_64)
  • Browser + version: FF / Chrome / Edge
  • Used idoit version: 1.15.2
  • Used idoit api version: any
  • Operating system idoit server: Ubuntu 20.04.1 LTS (GNU/Linux 5.4.0-58-generic x86_64)
  • You can update i-doit settings (on integration page) and add i-doit objects to Zammad Tickets without any trouble.
  • When trying to select i-doit objects for a ticket, the user receive error message: on trying to select i-doit objects in zammad I receive “Can’t fetch objects from http://idoit-hostname/src/jsonrpc.php: #”
  • Try to use the i-doit integration as in adding new objects to a ticket
Did you check idoit side logs for further hints?
Did you ensure to provide Client ID as mentioned per documentation?
https://admin-docs.zammad.org/en/latest/system/integrations/i-doit.html#how-to-set-it-up
