Used Zammad version: 6.5.2-1763472134.c8495510.bookworm
Used Zammad installation type: (source, package, docker-compose, …)
Operating system: Package
Browser + version: Firefox Browser + 145.0.2
No scaling of images when copying them with Ctrl+C and pasting them with Ctrl+V.
If you copy content with images from a previous email or internal note using Ctrl+C and then paste it into a new reply, new note, new ticket or also in a knowledge base article using Ctrl+V, the images contained therein will be scaled up significantly.
To avoid this, you currently have to mark and edit each image in the new answer/note/ticket or knowledgebase entry once (for example, resize it again using the interactors). Only then will the image return to its original size.
Copying an email or internal note message with images per CTRL + V within a new reply
Simply copy content (e-mail or internal note) with images using Ctrl+C into a new internal note/e-mail reply/new ticket or into a knowledge base entry using Ctrl+V.
Then select one image with the left mouse button—the image will then be displayed in its original size again. As soon as you deselect it, however, it will be displayed oversized again.
To resize the image:
Select the image again.
Use one of the interactors at the corners to scale the image minimally.
Click again with the left mouse button.
We’ve fixed the related issue, and the update for stable will be available shortly. This should also resolve the issue you described here. If it doesn’t, please let me know.
