temi
#1
I want to move zammad to a bigger server
apt will install with postgres. I have an old installation with mariadb and want keep maridb.
Yes I can install from source but apt-get upgrade is then no more possible for zammad
So how can I switch database when I install via apt-get?
What else I need to do?
I make a backup witch zammad_backup.sh and restore it on the new server what else I need to do to migrate it to the new server?
install mariadb before zammad.
zammad depends on…postgresql|mariadb-server|sqlite
see apt-cache show zammad
so, if you install mariadb first, zammad will use MariaDB.
(works on Debian 9)
temi
#3
I tried it but unfortunately it’s not the case. I know this was the case with older versions
system
Closed
#4
