Used Zammad version: 2.8.x
Used Zammad installation source: (source, package, …) package
Operating system: Ubuntu 16.04.5
Browser + version: Chrome
I want to use the group name (#{ticket.group.name}) in an email, that is send to the customer from a trigger. The group name is used in a link. When the group name has spaces in it, the link will be cut off. Is there a way to URL encode Strings in a trigger?
I cannot help you with the improper stripping of a group name, but if this not an issue - export your users into CSV, use awk/sed to remove spaces and change them to for example “_” in group names, reimport and it should temporarily solve your case.
Please do not treat my idea as an final solution. It’s just a shortcut.
I’m writing a survey tool that customers should be sent to when their ticket is closed. Since we support different products in our Zammad, we have created groups that represent the different products.
But I can’t produce the link like this, because our group names contain spaces. Otherwise I could just use #{ticket.group.name}. I had hoped that I could use some code in the editor for the mail from the trigger that url-encodes me such a variable. But I guess I have to use #{ticket.group.id} in the link to get the name of the group from the API. Or is there an easier way to do that?
