here’s the default reply when a ticket is created. there are some instances that the customer cannot see the reply of the agent because it was set to internal by default. is there a way that the default reply is set to public?
Please note that the screenshoted UI part is not an answer to your customer in a classical way. By default your customer will not receive any information via E-Mail.
Either use the reply button or create a trigger if needed.
