which file needs to be edited to change e.g. the colorscheme of the login screen?
BR
Nino
BR
Nino
Hey,
this might be what you’re looking for:
Please note that you need to precompile all assets to make changes productive.
You can also change existend css files, but -as walways- this is not update safe.
I am aware of the git, but I could not find the corresponding file (maybe my search skills are not that grand ) could you point me to the correct file?
BR,
Nino
There is no file, as this is the place where your custom css wants to live.
OK thanks for the explanation. This should be a good starting point.
BR,
NIno
