Hi there.
We need to limit the bulk-action functionality to a group of agents (a specific “Role”, for example).
Is is already possible to disable the functionality? If so, can you provide us with the steps needed?
Thank you.
Best regards.
Silvia
Hi there.
Thank you.
Best regards.
Silvia
