- Used Zammad version: latest
- Used Zammad installation type: (source, package, docker-compose, …) package
- Operating system: ubuntu 20.04
- Browser + version: chrome
hi all
How customer, in yours customer portal, can choise a priority ?
hi all
or this impossible ?
Zammads core does not allow customers to choose the ticket priority.
We believe that not the customer should decide how important a topic is, because the customer usually priotizses their issues higher than they really are.
If you must, you can workaround this with a combination of a custom select object and a series of triggers. We had this topic on this community board several times already. A search should help in case you’re not sure.
