- Used Zammad version: 2.5.0-1529668954.708c86ba.xenial
- Used Zammad installation source: Ubuntu Repo
- Operating system: Ubuntu 16.04.4 LTS
I have to “reopen” the following topic:
I have the same error again.
I did the following:
- Made a backup via the script (Backup and Restore — Zammad System Documentation documentation)
- downloaded the backup files (*_zammad_files.tar.gz & *_zammad_db.mysql.gz)
- Reinstall a plesk vServer
- Installed Zammad (Install from package — Zammad System Documentation documentation)
- create a subdomain and edited the vhost config (/var/www/vhosts/system/zammad.****.de/conf/vhost.conf) (zammad/contrib/apache2/zammad.conf at develop · zammad/zammad · GitHub)
- test to see if zammad is running and working/visit the subdomain zammad.****.de everything is fine i can start to “install” Zammad.
- restore via “./zammad_restore.sh 20170507121848”
- Visiting the domain will result in a 503 error and heavy load on the server
The error_log give me the following:
[Mon Jun 25 11:49:44.080852 2018] [proxy:error] [pid 11106:tid 140158689060608] AH00940: HTTP: disabled connection for (localhost) [Mon Jun 25 11:49:44.080915 2018] [proxy:error] [pid 11106:tid 140158689060608] AH00940: HTTP: disabled connection for (localhost) [Mon Jun 25 11:49:57.246460 2018] [proxy:error] [pid 11105:tid 140158689060608] (111)Connection refused: AH00957: WS: attempt to connect to 127.0.0.1:6042 (localhost) failed [Mon Jun 25 11:49:57.246503 2018] [proxy:error] [pid 11105:tid 140158689060608] AH00959: ap_proxy_connect_backend disabling worker for (localhost) for 60s [Mon Jun 25 11:49:57.246516 2018] [proxy_wstunnel:error] [pid 11105:tid 140158689060608] [client 5.146.221.179:35153] AH02452: failed to make connection to backend: localhost [Mon Jun 25 11:49:57.246701 2018] [proxy:error] [pid 11105:tid 140158689060608] (111)Connection refused: AH00957: HTTP: attempt to connect to 127.0.0.1:3000 (localhost) failed [Mon Jun 25 11:49:57.246714 2018] [proxy:error] [pid 11105:tid 140158689060608] AH00959: ap_proxy_connect_backend disabling worker for (localhost) for 60s [Mon Jun 25 11:49:57.246723 2018] [proxy_http:error] [pid 11105:tid 140158689060608] [client 5.146.221.179:35153] AH01114: HTTP: failed to make connection to backend: localhost
Any idea whats wrong?
