Fresh installation of .deb fails on Debian 11
  • Used Zammad version: 5.0.3-1640164755.9ed29355.bullseye
  • Operating system: Debian 11
  • working installation
Installation fails with hundreds of lines of tracebacks, starting with:
# (Re)creating init scripts
Nothing to do.
Nothing to do.
Nothing to do.
# Enabling Zammad on boot
# Stopping Zammad
# Clear cache...
rake aborted!
ActiveRecord::NoDatabaseError: FATAL:  role "zammad" does not exist
  • sudo apt install zammad
I removed both postgresql and zammad with apt --purge ... to get a clean state and started again, but the error remains the same.
Thanks in advance for any help!
PS: Documentation says for both Debian and Ubuntu:
$ apt install locales
$ locale-gen en_US.UTF-8
$ echo "LANG=en_US.UTF-8" > /etc/default/locale
This might work on Ubuntu, but not on Debian. Change it to:
$ sed -i 's/^# *\(en_US.UTF-8\)/\1/' /etc/locale.gen && locale-gen
Can someone fix the docs, please?
I got one step further, i.e. many tables have been CREATEd, after typing:
sudo -i -u postgres
export DB=zammad
export DB_USER=zammad
export DB_PASS=theonefromdatabase.yml
echo "CREATE USER \"${DB_USER}\" WITH PASSWORD '${DB_PASS}';" | psql
createdb -E UTF8 ${DB} -O ${DB_USER}
echo "GRANT ALL PRIVILEGES ON DATABASE \"${DB}\" TO \"${DB_USER}\";" | psql
And afterwards sudo apt install --reinstall zammad. But there was still an exception:
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.4/lib/active_record\
/connection_adapters/postgresql_adapter.rb:675:in `async_exec': ERROR:  insert or \
update on table "translations" violates foreign key constraint "fk_rails_d6e6d9635d" \
(PG::ForeignKeyViolation) DETAIL:  Key (created_by_id)=(1) is not present in table "users".
When I tried to create the admi account in the web interface, I got a similar error in the web browser: Couldn't find User with 'id'=1
After
sudo zammad run rake db:migrate
sudo zammad run rake db:seed
it looks like everything works. I’m a little bit surprised, that so many manual steps are necessary and it was not completely intuitive to find them. But, hey, that’s the fun of free software :slight_smile:
Debian 11 is still not supported by Zammad: https://docs.zammad.org/en/latest/prerequisites/software.html#supported-distributions
Oops, I was sure that I checked if current stable/11/bullseye were supported.
Thanks for pointing that out!
I wonder if it is worth the trouble to install again, this time on Debian 10 (buster)…
At least, that way I can see, if I have the same problems.
PS: Looks like at least packager.io does support Debian 11 now:
pkgr/debian.yml at master · crohr/pkgr · GitHub
I personally would do that, especially since with Debian you can always update your distribution later when Zammad supports it. This way you can be sure to have a clean working install, but that’s just my personal opinion.
Yes, I upgraded dozens of servers, VMs, even containers (don’t laugh) from 10 to 11 without relevant problems.
