Used Zammad version: 2.5.X
Used Zammad installation source: Package
Operating system: Ubuntu 16.04 LTS
Browser + version: Firefox 61.0 (64bit)
FreeIPA Users Groups associated with Groups in Zammad
Users Name Fields associated with the Right Name
Groups are just showing up under role, so there isnt any possibility to associated them centralised in ipa
User Name Fields are just showing up as Full Name Fields (first given name+Last Name)
I think ipa groups are meant to show up under role, the zammad role and ipa group have the same sort of purpose, they just use different names. I don’t know if you can create zammad groups through ldap sync, at least there’s not an obvious way through the gui.
The second part with the user name field, I don’t know what the right name is, but map them to what you want, I map them to uid.
