Forward option default is public and not internal
apparently the following is not considered a bug so I should post it as a feature request:
  • When Forwarding an article from a ticket to e.g. a none zammad group e-mail the forwarded message should be kept internal per default and the external reply as well.
  • This is particularly important if you work with external developers and you want to forward a customer bug report and keep the discussion between dev and support internal.
  • The forwarded message and the external reply received will both be logged publicly in the ticket.
  • Create ticket
  • Forward first article to none zammad group e-mail
  • Reply from the none zammad group e-mail
I fully agree with what SEGGER-NV said.
We could imagine a default visibility option for forwarded message and response, like the note default visibility parameter.
Thanks for your response
