Generate report by Group
The “First Respond At” should capture the DateTime when Agent responded (#3 above).
And, to calculate the “First Response In Min” and “First Response Diff In Min”.
38: from /opt/zammad/bin/rails:9:in `<main>'
37: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.3 /lib/active_support/dependencies.rb:291:in `require'
36: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.3 /lib/active_support/dependencies.rb:257:in `load_dependency'
35: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.3 /lib/active_support/dependencies.rb:291:in `block in require'
34: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bo otsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
33: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bo otsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_l fi'
32: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bo otsnap/load_path_cache/loaded_features_index.rb:65:in `register'
31: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bo otsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_b ootsnap_lfi'
30: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bo otsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
29: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.3/lib/ rails/commands.rb:18:in `<main>'
28: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.3/lib/ rails/command.rb:46:in `invoke'
27: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.3/lib/ rails/command/base.rb:69:in `perform'
26: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor.r b:392:in `dispatch'
25: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/i nvocation.rb:127:in `invoke_command'
24: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/c ommand.rb:27:in `run'
23: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.3/lib/ rails/commands/runner/runner_command.rb:41:in `perform'
22: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.3/lib/ rails/commands/runner/runner_command.rb:41:in `eval'
21: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.3/lib/ rails/commands/runner/runner_command.rb:41:in `<main>'
20: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/core.rb:197:in `find_by'
19: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/querying.rb:9:in `find_by'
18: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/relation/finder_methods.rb:81:in `find_by'
17: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/relation/finder_methods.rb:103:in `take'
16: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/relation/finder_methods.rb:504:in `find_take'
15: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/relation.rb:200:in `records'
14: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/relation.rb:422:in `load'
13: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/relation.rb:547:in `exec_queries'
12: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/relation.rb:584:in `skip_query_cache_if_necessary'
11: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/relation.rb:560:in `block in exec_queries'
10: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/querying.rb:41:in `find_by_sql'
9: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/connection_adapters/abstract/query_cache.rb:106:in `select_all '
8: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/connection_adapters/abstract/database_statements.rb:68:in `sel ect_all'
7: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/connection_adapters/abstract/database_statements.rb:482:in `se lect_prepared'
6: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/connection_adapters/postgresql/database_statements.rb:81:in `e xec_query'
5: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/connection_adapters/postgresql_adapter.rb:600:in `execute_and_ clear'
4: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/connection_adapters/postgresql_adapter.rb:617:in `exec_cache'
3: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/connection_adapters/postgresql_adapter.rb:672:in `prepare_stat ement'
2: from /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
1: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/ lib/active_record/connection_adapters/postgresql_adapter.rb:677:in `block in pre pare_statement'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record /connection_adapters/postgresql_adapter.rb:677:in `prepare': ERROR: column tick et_articles.name does not exist (PG::UndefinedColumn)
LINE 1: ... "ticket_articles".* FROM "ticket_articles" WHERE "ticket_ar...
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record /connection_adapters/postgresql_adapter.rb:677:in `prepare': PG::UndefinedColumn : ERROR: column ticket_articles.name does not exist (ActiveRecord::StatementInv alid)
: SELECT "ticket_articles".* FROM "ticket_articles" WHERE "ticket_articles"."na me" = $1 LIMIT $2
Actually, it is resolved as posted earlier, which following your post title “Add communication-trick for SLA notes”.
I able to capture “First Respond At” timestamp with the ticket’s 1st note.
