- Used Zammad version: 3.6.0
- Used Zammad installation source: source within custom Docker containers
- Operating system: Host: Ubuntu 20.04, Docker containers based on ubuntu:20.04
- Browser + version: Firefox 84.0.2 (on Ubuntu 20.04)
Scheduled tasks are conducted and the webinterface is updated properly (considering the task state).
Scheduled tasks are run by the scheduler as expected, but the the rest of Zammad doesn’t seem to get notified about it.
Use case 1:
A user is deleted, the deletion task is run properly by the scheduler, the state within the webinterface doesn’t get updated (stays at ‘in process’).
- Setup fresh Zammad
- Delete example user
- Watch the privacy data task state
Scheduler log
I, [2021-01-21T09:14:10.937793 #1-70327549038780] INFO -- : execute DataPrivacyTaskJob.perform_now (try_count 0)...
I, [2021-01-21T09:14:10.938268 #1-70327549038780] INFO -- : Performing DataPrivacyTaskJob (Job ID: 63bc340a-402a-4320-8aac-271579470f32) from DelayedJob(default)
I, [2021-01-21T09:14:12.557570 #1-70327549038780] INFO -- : Enqueued TicketCreateScreenJob (Job ID: 30abd6f2-a1a8-45c5-9525-bc3bd3908244) to DelayedJob(default) at 2021-01-21 08:14:22 UTC
I, [2021-01-21T09:14:12.593244 #1-70327549038780] INFO -- : Performed DataPrivacyTaskJob (Job ID: 63bc340a-402a-4320-8aac-271579470f32) from DelayedJob(default) in 1654.85ms
I, [2021-01-21T09:14:12.593433 #1-70327549038780] INFO -- : ended DataPrivacyTaskJob.perform_now took: 1.662182316 seconds.
Use case 2:
LDAP integration is configured, users should be imported, configuration dialog stays at ’ Counting entries. This may take a while.’ indefinitely.
- Configure LDAP integration for the first time
Scheduler log
I, [2021-01-21T09:28:08.346334 #1-47249299742760] INFO -- : 2021-01-21T09:28:08+0100: [Worker(host:a7129ab8f5ce pid:1)] Job AsyncImportJob [13ab6015-e3c1-49d4-b238-834930b3a1e3] from DelayedJob(default) with arguments: [{"_aj_globalid"=>"gid://zammad/ImportJob/1"}] (id=25) (queue=default) RUNNING
I, [2021-01-21T09:28:08.375590 #1-47249299742760] INFO -- : Performing AsyncImportJob (Job ID: 13ab6015-e3c1-49d4-b238-834930b3a1e3) from DelayedJob(default) with arguments: #<GlobalID:0x00007fecd17385f0 @uri=#<URI::GID gid://zammad/ImportJob/1>>
I, [2021-01-21T09:28:09.192676 #1-47249299742760] INFO -- : Performed AsyncImportJob (Job ID: 13ab6015-e3c1-49d4-b238-834930b3a1e3) from DelayedJob(default) in 816.89ms
I, [2021-01-21T09:28:09.196384 #1-47249299742760] INFO -- : 2021-01-21T09:28:09+0100: [Worker(host:a7129ab8f5ce pid:1)] Job AsyncImportJob [13ab6015-e3c1-49d4-b238-834930b3a1e3] from DelayedJob(default) with arguments: [{"_aj_globalid"=>"gid://zammad/ImportJob/1"}] (id=25) (queue=default) COMPLETED after 0.8499
Additional infos:
All other parts of Zammad seem to work properly.
Docker stack:
On top of this stack, there is a central nginx server, conduction SSL encryption and forwarding the /ws requests to port 6042.
I suspect the problem to be a communication problem between the scheduler and the rails server, I cannot find any error in any log though.
How is the acknowledgement of successful scheduler tasks working?
I’m very thankful for every little hint!
