This is not so much a “I have a technical problem” question.
I’m trying to ascertain whether Zammad is a good fit for the problem my organisation has.
The data we want to register per ticket is somewhat nested and quite a lot. The currently available types for Object attributes are not sufficient for our use case.
I was thinking I could extend Zammad (either core or through some a plugin system) as follows. I could set the Object attribute to JSON. It would be a JSON string in the database then. I’d have to supply a .js
file at the same time which would create the dynamic UI for the CRUD-operations on this field. Then lastly for exporting purposes (or maybe filtering/searching purposes) I’d have to supply some code (in a .rb
file?) that would be called every time the data in the field needs to be unpacked.
Does this sound reasonable? Or is this a BAD IDEA™?
Thanks!
