I would like to export users / organizations as separate CSV files.
This kinda already done with sample of Zammad data through the Import GUI interfaces under
Setting > Users > Import > Example CSV file for download
or
Setting > Organization > Import > Example CSV file for download
Screenshot
So if it is possible I would like to type/run some sort command to export all users or organization to CSV file.
This is not going to be needed much if at all but handy to be able to export if it required. As in most cases you use the Zammad backup command.
