Error when creating elasticsearch index with custom fields
  • Used Zammad version: 6.5.0
  • Elasticsearch Version: 8.17.4
  • Operating system: Ubuntu
  • Browser + version: Chrome
  • Search index is created
I run the following command:
docker exec zammad6-zammad-railsserver-1 /docker-entrypoint.sh rake zammad:searchindex:rebuild --trace
No errors in elasticsearch log. But the searchindex:rebuild does report the following error multiple times:
Caused by:
Unable to process post request to elasticsearch URL
'http://zammad-elasticsearch:9200/zammad_production_ticket/_doc/13680?pipeline=zammadf94edf71-edcf-4ed5-b759-a47b0d818d81'.
Check the response and payload for detailed information: Response:
#<UserAgent:: Result: 0x00007f4a09e9c7d0 @success=false,
@body="{\"error\":{\"root_cause\":[{\"type\":\"parsing_exception\",
\"reason\":\"Failed to parse object: expecting token of type [START_OBJECT] but found [VALUE_STRING]\",\"line\":1,\"col\":543}],
\"type\":\"document_parsing_exception\",
\"reason\":\"[1:543] failed to parse field [order] of type [flattened] in document with id '13680'. Preview of field's value: ''\",
\"caused_by\":{\"type\":\"parsing_exception\",\"reason\":\"Failed to parse object: expecting token of type [START_OBJECT] but found [VALUE_STRING]\",
\"line\":1,\"col\":543}},\"status\":400}",
@data=nil, @code="400", @content_type=nil, @error="Client Error: #<Net::HTTPBadRequest 400 Bad Request readbody=true>!",
@header={"x-elastic-product"=>"Elasticsearch", "content-type"=>"application/json", "content-length"=>"508"
Payload (Stripped irrelevant fields)
   "id": 13680,
  "created_at": "2025-06-05T13:35:39.588Z",
  "updated_at": "2025-06-05T14:25:51.918Z",
  "offer": "",
  "order": "",
  "last_close_at": "2025-06-05T14:25:51.925Z",
  "checklist_id": null,
It seems that elasticsearch is not accepting empty strings in the offer and order field.
  • Create text fields with name “offer” and “order” in Zammad on ticket level
  • Run rake zammad:searchindex:rebuild
I run 6.5.0-53 docker version of zammad.
Here is some context to the error. Is it elasticsearch 8 related?
https://stackoverflow.com/questions/71204453/elasticsearch-8-0-0-mapper-parsing-exception-of-a-string-literal-for-field-type
Either zammad should post the custom field as object in the request JSON to es or the index must be created to support the correct string type.
Another issue is, that index creation is working in general, until the create index script returns with an error:
/opt/zammad/lib/search_index_backend.rb:812:in `make_request_and_validate'
/opt/zammad/lib/search_index_backend.rb:151:in `add'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:154:in `search_index_update_backend'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:208:in `block in search_index_reload'
/usr/local/bundle/gems/parallel-1.26.3/lib/parallel.rb:650:in `call_with_index'
/usr/local/bundle/gems/parallel-1.26.3/lib/parallel.rb:417:in `block in work_direct'
/usr/local/bundle/gems/parallel-1.26.3/lib/parallel.rb:660:in `with_instrumentation'
/usr/local/bundle/gems/parallel-1.26.3/lib/parallel.rb:416:in `work_direct'
/usr/local/bundle/gems/parallel-1.26.3/lib/parallel.rb:285:in `map'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:204:in `search_index_reload'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:42:in `block (5 levels) in <main>'
/usr/local/bundle/gems/benchmark-0.4.0/lib/benchmark.rb:323:in `realtime'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:41:in `block (4 levels) in <main>'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:39:in `each'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:39:in `block (3 levels) in <main>'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/task.rb:281:in `block in execute'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/task.rb:281:in `each'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/task.rb:281:in `execute'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:60:in `block (3 levels) in <main>'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/task.rb:188:in `invoke'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/application.rb:188:in `invoke_task'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/application.rb:138:in `each'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/application.rb:138:in `block in top_level'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/application.rb:147:in `run_with_threads'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/application.rb:132:in `top_level'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/application.rb:83:in `block in run'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/application.rb:214:in `standard_exception_handling'
/usr/local/bundle/gems/rake-13.2.1/lib/rake/application.rb:80:in `run'
/usr/local/bundle/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
/usr/local/bundle/bin/rake:25:in `load'
/usr/local/bundle/bin/rake:25:in `<main>'
Tasks: TOP => zammad:searchindex:rebuild
It’s a problem, that e.g. the user index is not created yet and thus also the user search is not working, even if it could. The zammad:searchindex:rebuild just need to continue with the remaining indexes, eve if a single index fails.
It would also help to get a command to rebuild single indexes or to controll which parts to use es for and where to just use the DB (user search via DB would be perfectly fine for me).
Seems like “order” is a very bad name for a custom field … I just found the following zammad code that takes all columns called “order” and applies the es schema type “flattened” to it.
I will rename the column and check if it fixes my issue…
Did the renaming fix it?
