Error during upgrade from 6.1 to 6.2
  • Used Zammad version: 6.1
  • Used Zammad installation type: apt package
  • Operating system: debian 11
  • Browser + version: Edge
  • update running flawless
  • The update process throws a few errors, alle seem to be related to the table smime_certificates.
    However, the update continues and installs the 6.2 version, but login (via LDAP) and mailing does not work anymore. When logged in via the Zammad-Admin Account both, LDAP an EMAIL are still there, but most fields empty.
Comment: We’re still on mariaDB; I tried to migrate to pgSQL, but the issue with the mentioned table prevented a successful migration
  • re-run update from the latest 6.1 version to the first available 6.2 version
Extract of the protocol:
2024-04-23T19:43:20.432000Z NOTICE ALTER TABLE public.user_two_factor_preferences ADD CONSTRAINT fk_rails_331b8c0f48 FOREIGN KEY(created_by_id) REFERENCES public.users(id) ON UPDATE RESTRICT ON DELETE RESTRICT
2024-04-23T19:43:20.433000Z NOTICE ALTER TABLE public.user_two_factor_preferences ADD CONSTRAINT fk_rails_486740ea12 FOREIGN KEY(updated_by_id) REFERENCES public.users(id) ON UPDATE RESTRICT ON DELETE RESTRICT
2024-04-23T19:43:20.443000Z NOTICE Executing SQL block for after load
KABOOM!
FATAL error: Database error 42703: Spalte email_addresses existiert nicht
QUERY: alter table smime_certificates alter column email_addresses type text using translate(email_addresses::text, ‘’, ‘{}’)::text
An unhandled error condition has been signalled:
2024-04-23T19:43:20.449000Z ERROR Database error 42703: Spalte email_addresses existiert nicht
Sorry I can’t follow. Are you having issues upgrading Zammad or are you trying to migrate MariaDB to PostgreSQL?
Hi, sorry for the confusion. The database thing was just an added information.
We have problems to upgrade to 6.2, but we’re still on MariaDB. I found some hints, but they were focused on PostgreSQL, so I thought it might be a good point the mention this…
Make sure that your migrations are up to date before upgrading.
zammad run rake db:migrate should do that (if there’s open ones).
Hi there!
Thanks for the feedback. yes, that’s what I tried several times already, but it did not (!) fix the issue.
zammad run rake db:migrate --trace
** Invoke db:migrate (first_time)
** Invoke db:load_config (first_time)
** Execute environment
** Execute db:load_config
** Execute db:migrate
== 20230726082734 SMIMEMetaInformationTable: migrating ========================
– change_table(:smime_certificates)
rake aborted!
StandardError: An error has occurred, all later migrations canceled:
No indexes found on smime_certificates with the options provided.
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/connection_adapters/abstract/schema_statements.rb:1411:in index_name_for_remove' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/connection_adapters/abstract/schema_statements.rb:881:in remove_index’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/connection_adapters/abstract/schema_definitions.rb:711:in remove_index' /opt/zammad/db/migrate/20230726082734_smime_meta_information_table.rb:24:in remove_columns’
/opt/zammad/db/migrate/20230726082734_smime_meta_information_table.rb:15:in block in migrate_table' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/connection_adapters/abstract/schema_statements.rb:490:in change_table’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:929:in block in method_missing' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:897:in block in say_with_time’
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/benchmark.rb:296:in measure' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:897:in say_with_time’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:918:in method_missing' /opt/zammad/db/migrate/20230726082734_smime_meta_information_table.rb:14:in migrate_table’
/opt/zammad/db/migrate/20230726082734_smime_meta_information_table.rb:8:in change' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:867:in exec_migration’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:851:in block (2 levels) in migrate' /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/benchmark.rb:296:in measure’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:850:in block in migrate' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:462:in with_connection’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:849:in migrate' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1037:in migrate’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1329:in block in execute_migration_in_transaction' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1382:in ddl_transaction’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1328:in execute_migration_in_transaction' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1302:in each’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1302:in migrate_without_lock' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1251:in block in migrate’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1401:in block in with_advisory_lock' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1416:in block in with_advisory_lock_connection’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:462:in with_connection' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1416:in with_advisory_lock_connection’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1397:in with_advisory_lock' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1251:in migrate’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1086:in up' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/migration.rb:1061:in migrate’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/tasks/database_tasks.rb:237:in migrate' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/railties/databases.rake:92:in block (3 levels) in ’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/railties/databases.rake:90:in each' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activerecord-6.1.7.6/lib/active_record/railties/databases.rake:90:in block (2 levels) in ’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:281:in block in execute' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:281:in each’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:281:in execute' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:219:in block in invoke_with_call_chain’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:199:in synchronize' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:199:in invoke_with_call_chain’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:188:in invoke' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:160:in invoke_task’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in block (2 levels) in top_level' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in each’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in block in top_level' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:125:in run_with_threads’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:110:in top_level' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:83:in block in run’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:186:in standard_exception_handling' /opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:80:in run’
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/exe/rake:27:in <top (required)>' /opt/zammad/vendor/bundle/ruby/3.1.0/bin/rake:25:in load’
/opt/zammad/vendor/bundle/ruby/3.1.0/bin/rake:25:in <top (required)>' /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:58:in load’
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:58:in kernel_load' /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:23:in run’
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:486:in exec' /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/command.rb:27:in run’
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/invocation.rb:127:in invoke_command' /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor.rb:392:in dispatch’
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:31:in dispatch' /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/base.rb:485:in start’
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:25:in start' /opt/zammad/vendor/ruby-3.1.3/lib/ruby/gems/3.1.0/gems/bundler-2.3.26/libexec/bundle:48:in block in <top (required)>’
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/friendly_errors.rb:120:in with_friendly_errors' /opt/zammad/vendor/ruby-3.1.3/lib/ruby/gems/3.1.0/gems/bundler-2.3.26/libexec/bundle:36:in <top (required)>’
/opt/zammad/bin/bundle:121:in load' /opt/zammad/bin/bundle:121:in
Caused by:
ArgumentError: No indexes found on smime_certificates with the options provided.
Tasks: TOP => db:migrate
Can you please verify that the content of the affected migration is the same as upstream?
Hm - checked this file and it was, indeed, slightly different to the one on GITHUB - I do have the previous version on my server.
Even after changing this file the
“zammad run rake db:migrate --trace” didn’t finish properly.
Hi There,
unfortunately this is not solved, yet.
It seems, that at some point the migration scripts did not run properly. We now had to migrate from a local email account to m365. This worked …somehow… but we cannot send from within a ticket - the icon is missing.
Upgraded to 6.3 (6.3.1-1726476083.3af12932.bullseye, to be specific) - but the issue remains…
I’m afraid we by now found the issue. It was caused by a not entirely correct pgloader script. You can learn more here:
You will basically have to correct the column type within the smime table manually. This is a fairly dangerous operation. Have a backup at hand.
